Trouble registering?
[phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Postby stuartcnz » Wed Jun 26, 2013 12:49 am
Now days, things are locked down pretty tight. When it comes to registering, I need to be confidant that you are a real person, so I do a few checks.
At the very least set your time zone, to where you are registering from, other wise you will be deleted and banned from the site.
It's not just spam on the forum that is an issue, but also the integrity of our existing members email addresses that need to be protected.
In the future when time is more available, I may be able to put measures in place, that once again opens things up, like Sharkey use to have it, hopefully even allowing guest posting again. But that time, is not now.
https://hubzilla.nomadicista.org/channel/stuart
sip:stuart@nomadicista.nz (TLS connections only)
Return to “Forum How To's & Announcements”
