Wayne Bus'es - Mobicile
Posted: Fri Dec 25, 2009 8:11 pm
Wayne bus
SAFETY FIRST....!
The benefits of the "Wayne Bus"-Lifeguard" design was proved in several potentially catastrophic collisions. For example, in 1982, at Petersburg, Virginia, a 1973 model Wayne Lifeguard school bus transporting 41 elementary school children was struck broad-side at an intersection by a fire truck which had gone through a red traffic signal without stopping while responding to an alarm. The school bus was rocked violently, but after the fire truck literally BOUNCED OFF of it (rather than penetrating the body) The driver was able to regain control and bring it to a safe stop. The fire truck was SPUN 180' and ITS FRONT was DEMOLISHED. All 3 firefighters were hospitalized. ONE CHILD on the bus had a BROKEN ARM;... THE REST UNINJURIED. Later examination of the school bus revealed that the impact of the MASSIVE WATER LAIDENED FIRE TRUCK HAD FAILED TO OVERCOME THE GREAT STRENGTH OF THE "WAYNE BUS" CONSTRUCTION and GAURD RAIL SYSTEM. Investigators were amazed to discover that there had been NO PENETRATION of the passenger compartment, NO JOINT SEPARATION, and NO SHARP EDGES WERE CREATED.( unlike ALL other makes and models ) Instead, they found the substantial impact stress had been shared over a widespread area along the entire structure of the "box", protecting the occupants as intended. In the years after Wayne introduced the Lifeguard in the 1973 model year competing body manufacturers began moving towards using a lesser number of side panels and joints, although NONE had been as progressive as Wayne. When the focus on structural integrity resulted in the joint requirements of the all-important U.S. Federal Motor Vehicle Safety Standards for school buses, most of which became applicable on April 1, 1977.
A Mobicile - is a mobile-domicile...
These videos were recorded from my T-Mobile G-1 Phone, and uploaded to a website called " Qik ". Go there and search " Bus Wheel Estate Project " Its a website that archives all of my phones , streaming-live videos , so that they "supposedly" - be viewed by others. I noticed when clicking the video links using my cell phone , there's a 20 second or so delay, before the video starts up , but other then that , they seem to work fine. It could be a bug involving the videos being seen from desktop computer -verses- being viewed from a cell phone computer....I don't own a desk or laptop computer...so I can't check my quess for accuracy...
Unfinished - Outside walk around
http://www.youtube.com/watch?v=JoTPPmrj ... tube_gdata
Unfinished - Rooftop deck
http://www.youtube.com/watch?v=FqCtSFyn ... tube_gdata
Unfinished - Inside - Walk thru
http://www.youtube.com/watch?v=9JUodyQQ ... tube_gdata
Unfinished - Inside - Rear-forward view
http://www.youtube.com/watch?v=ThjW-NJ8 ... tube_gdata
Here's the materials and assembly techniques I used in making a durable, outside, weather proof-road proof, insulated-underbelly. I've employeed the use of Dow Ridgid Foam sheet insulation, packing tape, liquid nails, and steel 2x4x8 studing-tracks. The purpose of this insulation unit, is to conserve the expensive electicity, produced by the generator, for air conditioning. It also aids in reflecting infa-red and radiant heat back to the road surface, instead of allowing it to passively accumulate underneath of the buses cabin, warming the floor area in the summer. This insulation unit will go a long way in providing great comfort and savings over the ownership of this home...These videos are somewhat long and tedious in how long the details are viewed. This over-lulling, was done so that one could follow ( if desired ) with acceptable results, while "freeze framing" about what,to do next...When loading these videos, one should expect a long delay, before video cranks up with a viewable picture. Patients is most helpful...
Added February 26th 2010 7:30 pm: EST.
This outdoors video shows an insulation tray applied to the underneath of the buses cabin. Video concentrates on the underneath, finished drivers side, as compared to the raw unfinished passingers side. http://qik.com/m/v/4d31307204e64383854d1424dde3bbbd/dl
Added on Febuary 25th 2010. 6:17 pm: EST.
this video verbally explains the how's and why's of my decisions concerning the design and the use of the raw materials used to make an insulation tray, and shows a completed tray , not yet fastened in place.
http://qik.com/m/v/f8097e92504643599f0efaebce625e49/dl
Added Febuary 24th 2010. 7:08 pm: EST. This video shows how to make a insulation tray. The use of minature pieces was substituted for the actual larger stock materials due to display space-confinements.
http://qik.com/m/v/4df5a2c2e4414affabaeab388cae9f18/dl
Here's an unfinished and unapplied,stack of: 2.5"x4'x8' sheet-styrofoam insulation material for building the exterior mounted-Rooftop Insulation Saddle. These 4 X 8 sheets are to be quadrupaled in thickness for buses width & length, resulting in a wide & long, insulation-saddle,outside of R-50
http://qik.com/m/v/b3f90c82cab840b9868b09172842424d/dl
ADDED, 04 -17-10
This is a view of the construstion of the inside, passinger walls. The outermost plywood is a 3/4" plywood panel, and the innermost plywood panel is 5/8" that sandwihes 3 pieces of Dow foam insulation . The insulation sheet thicknesses are as follows : the outermost piece is 0.5 (R3) + 1.5(R-7) + 1.5(R-7) = 3.5 (R-17)
http://www.youtube.com/watch?v=BCRAq3G- ... tube_gdata
ADDED, 05 -12-10
This is the bus in mid process of a hand rolled paint job with a white-oil based Rustoleum paint. On a Wayne Bus, the windows can be easily removed from the exterior, so that pre-taping a slop gaurd around the windows trim, isn't a neccessity.
http://www.youtube.com/watch?v=pVgjNtie ... tube_gdata
SAFETY FIRST....!
ADDED, 04 -17-10
ADDED, 05 -12-10
