Dusty's Bus
dusty,
That picture of your friends place in the trees with the old trucks is uncanny!! Did you take that in southwest Missouri, USA??
There is a guy whose place we go buy from time to time that looks a LOT like that - I got some deja vu going there just looking at it.
I have talked to the US guy a couple times and he won't sell. Your friend probably won't either, will he?
Sharkey , it certainly is a project , and it's taking me waaay longer than I am happy with , but progress is being made , so that's ok then.
The original Beddy engine is 330 cu about 5400cc and 98 hp, mind you , some of those horses were lame when new
The Nissan is an FE6 which is 6900cc and 180hp . So thats all good.
Unfortunately , as you would expect , nothing is the same size , so everything needs to be made to make it work.
It's ok , it just takes TIME.
The power steering has to be certified by an Engineer, so there goes a bunch of money , then it's back to the regular 6monthly roadworthy inspections.
I have pulled the head off the 330 and discovered that #4 piston has smeared itself up the bore , so that's nice to find the actual cause of the seize.
Dusty's Bus
Oh Dusty that's awful, but I can relate. Was going to fix something on my van and the tools had "walked" away
Good thing Rob can come over Weds & fix it for me!
Good Luck & if you need a rad and can't find it let me know and I'll help if I can.
Been a Nissan FANATIC since I was 16
Lois
Lois
Bash On Regardless!
I used to have a lovely dobermann , quiet and deadly he was , but they only live for so long.
Mostly I am very happy that New Zealand is not a "gun society" but just occasionally I change my mind.
I wasted a day looking locally for a replacement radiator, with no success, it seems I will have to get something shipped down from Hamilton , even just the top and bottom tanks will do , I can put a core in between them.
Money first , eh.
Money first , eh.
Re: Dusty's Bus
Well, it's been 6 months since the bus engine failed , we've had some more earthquakes , especially destructive in June, then freezing weather with snow over the whole country, then I stood where I should not have and ended up on crutches for a while .....
So progress on the repower has been S L O w .......
I'm adding power steering in this project , so here is a quick update , pic shows the bracket I had to make to adapt the nissan 'box to the old Bedford chassis.
more later .....
more later .....
Re: Dusty's Bus
Hard to know where not to stand sometimes... Thanks for the update.
Re: Dusty's Bus
I'm with you on the slow progress. I can finally get started on my truck. >.<
Re: Dusty's Bus
hows the bus doing ,dusty
Re: Dusty's Bus
Due to unforeseen circumstances, this topic has lost several of the most recent posts!
Users browsing this forum: No registered users and 138 guests
