somewhereinUSA build
Re: somewhereinUSA build
That's an interesting setup, Dick. Glad to see everyone getting ready for a little summer fun!
Darryl
Smyrna GA
2000 Gillig Phantom
Smyrna GA
2000 Gillig Phantom
This is just a teaser, I just finished making some really cool LED light fixtures. I don't want to show pics until I get them installed.
Hey Dick, those accent lamps really add a finished touch. As always, your project was well thought out and beautifully executed.
Two words of warning though. You'll want to avoid showing off your work while you are parked in the parking lot of the steak house where the dip cups came from--just kidding, and I don't think the dog has anything to fear until the lights go out and you have lost your night vision to those new lamps. Ha, Ha.
Jack
Jack
Jack,
I did see a really neat stainless basket that a place I ate at delivered the french fries in. May have been TGIF, don't remember now. I even went on line to see if I could buy it some where, no joy. I thought it would make a neat light fixture. I enjoy making my own, am appalled at how much LED fixtures cost.
generator
I've posted this other places, thought someone here might have some insite. This forum tends to have better innovators/thinkers on it.
I got my generator install pretty much done. It's a 20HP Kubota running a 320A 12V DC alternator. I ran both AC for about a half hour until overtemp shutdown. With no load it runs steady 194° The two temp gauges on my control panel are upper-engine temp, lower-top of radiator for fan control. Right now I have overtemp at 219° F, but can't really find any spec on what would be too hot. Ambient air temp is 89° F. Biggest problem is it's too loud. Inside in the rear is 57db, I can get that down with some better sound deadener. But outside in rear it's 77db, not sure what to do about that. I think the alternator itself is a bit noisy, I'll have to take the belt off to check that. There is also a low oil pressure shutdown.
Video of it running.
https://youtu.be/SncTm6bmgbI
Jack (ol trunt) suggested that he uses oil temp (194°F) for shut down. He also used horse stall mat to block noise.
Any thoughts?
Any thoughts?
I started this in response to the hello post then decided it was hijacking that thread. I'm making a shower door out of walnut and some cut down bus side windows. I found out that cutting laminated glass isn't really all that hard.
This is a section of a walnut log that was left over after I sold a tree to a lumber company, they leave a lot. My bandsaw will only make a 5 1/2 inch cut so I made a guide to cut my logs down. Walnut is really heavy and tough to cut with a chainsaw. Mumsywumsy wasn't happy about all of the saw dust on here roses.
Here's a handrail that I made out of a cherry log. The log had a rotten center, this is about all I got out of a 7 inch log.
Dick
Dick
Nice!
I envy the way you make all that wood work look so easy
Jack
Jack
Thanks Jack, just another excuse to buy more toys. I do enjoy being cheap and figuring out how to get what I want without spending for the new fancy stuff.
It's been a while since an update. Over the winter I finished the inside of another closet. Installed a hidden storage compartment with very secret locking mechanism. Got the main awning installed on the right side.
I just finished my sound system. I had been wanting to put in an old amp I had to power a bass speaker. Since the new awning has speakers I figured it was about time to redo the mess above the driver seat too.
Here's the radio cabinet which has the amp inside. It has my rear camera screen, XM receiver and new to me radio receiver. The new receiver has usb on front to play my books, also has bluetooth if I ever decide to pair with phone.
I recently got a new toy. It's a hand held CNC router. What better project than a grill for my speaker. This started out as what was left after I sold some walnut trees. (they leave a lot) I cut a piece with my chainsaw into a usable size that I could get into my bandsaw, cut the boards then plained, then edge glued a few together with some tenons.
The panel for the radio cabinet was also cut with the new toy. After all of that I still haven't hooked up the awning speakers. they are all wired but, I want to add a switch so I can turn them off. More wiring to figure out.
I don't understand how "hand held" and "CNC" work in the same sentence , but that speaker grill is beautiful .
Beautiful wood!! Love walnut!
I can see the recent pics, but the older ones are still showing up as photobucket blocked - didn't know if you knew about that or not...
I'ts pretty slick. Here's a link to their website.Dusty wrote:I don't understand how "hand held" and "CNC" work in the same sentence , but that speaker grill is beautiful .
https://shapertools.com
Users browsing this forum: No registered users and 20 guests
