propane fridge
Posted: Sat Apr 30, 2011 8:42 am
				Gentlemen-
I would like to thank you for the help and knowledge with the propane fridge that I scavenged from a 70's camper. It appears that the propane system is at least opperational. The electrical heating element needs to be replaced but as Greydawg (a special thank you))suggested ,I did confirm that the cooling unit is still operational. It is of the older varity and requires
extra leveling consideration ,but it does work. Next, replacing the electric heating element and a good tune up... Unfortunately this dictates a new refurbishing of the interior which is probably a given, you never are satisfied with your first attempt.
Are any of these parts still avaliable through Dometic ?
