The best bus to purchase
Posted: Fri May 13, 2011 9:37 am
				I have heard the question asked, "What is the best bus I should purchase?" more than once.
My answer has always been, there is no one size fits all bus out there. As a consequence, you as the purchaser need to determine how you are going to use the bus before you ever purchase your bus. Where you use your bus and how you are going to use your bus will have a very big impact upon what you purchase as well. The wrong bus can end up costing you not only a lot of $$$ but a lot of time and trouble as well.
I don't know about most of you but I never have enough time and $$$. And as far as aggravation goes, I have more than my share of it so I don't deliberately go looking for it.
Having said all of that I will give a short primer on buses.
Buses come in four basic kinds--school buses, commercial buses, transit buses, and motorcoaches. Each of those categories can then be further divided into several further categories by size and use.
For all practical purposes DO NOT consider any commercial bus for conversion. Most have some sort of composite body mated to an OEM supplied chassis. In the out years, the marriage between the body and the chassis usually ends up in a very bad divorce. The vast majority are built with a whole lot more bus than there is truck underneath. And very few have any space down below for anything.
Transit buses can be found for sale at very low prices. They come in many different sizes from very short to 60' articulated versions and 45' double decker versions. Most that have been built since the mid-90's are 102" wide. Their advantage is they have a lot of headroom. Their real disadvantage is they have very little space under the bus and most of the time do not have highway gearing. And until recently most were built with V-drive power packages that severely limit any repower or regearing possibilities.
School buses come in four types--Type A (mini-buses built on van-cutaway chassis, most often Ford E-350 chassis), Type B (also classed as mini-bus but built on a rail chassis, most often on the GM P-30/Workhorse chassis, with the service door behind the driver and the front axle), Type C (conventional chassis, most often made by IHC, in sizes from as few as four rows of seats to as many as 13 rows of seats with some having a driven front axle), and the Type D (in three different versions with the engine in front, or mid-mount, or in the rear with as few as 7 rows and as many as 16 rows). The downside of the school bus is that until the last few years most were relatively underpowered and struggle to maintain the truck speed limit. The upside is they are cheap, they are rugged enough to get off road (within reason), there are few roads in the country they don't travel up and down twice a day, and if they don't have underside luggage compartments there is plenty of room to add some.
The motorcoaches come in many sizes with the most common being 35', 40', 45', and a very few that were 60'. The 35' and some of the 40' buses have two axles. Most 40' and all 45' buses have three axles with most of the third axles either a bogey or trail axle. The 60' has five axles. Almost all motorcoaches built since the mid-90's have been 102" wide. Very few have two driven axles. All have large underfloor storage compartments. The real upside to the motorcoaches is that they are designed and built for the long highway trips. They have the power and gears to push the speed limit just about anywhere. The downside for most motorcoaches is their size. Not only are they long but they are tall. Most are at least 12' tall and some are more than 13' tall. With their height and length also comes a lot of weight. Their size can limit your accessibility to second class highways and back roads. Finding weight or height restrictions on a road that requires you to back up for miles to find a place to turn around is never fun. They also are the most expensive to purchase and the most expensive to maintain--the more axles you have the more brakes, tires, bearings, etc. that you have to maintain. They also have heavy duty diesel engines with matching transmissions that can cost a ton if anything goes wrong.
So again, before you go out and purchase a bus you need to determine what exactly you plan to do with your bus and where you plan to go with it. Until you answer those questions it is really hard to know how to advise you as to what bus would be the best for you to purchase.
Good luck.
Good luck.
