Battery cables
Posted: Tue Feb 05, 2013 10:30 am
I know there are some engineers here, so I've got a question.
Started assembling my new battery cables and ran into a problem. I bought 4/0 cable(clearly marked AWG 4/0) and 4/0 crimp on lugs. Started first end, and the lug is no where near big enough to go over the cable. I thought well darn, they sent the wrong lugs. Looked up the specs,4/0 cable end is supposed to be .548 mine measure .548. I looked up cable specs, 4/0 is supposed to be .460, that would fit very nicely. My cable measures, on average about .600. Since I wouldn't be making the cable less than 4/0 is it permissible to cut enough strands off to fit into the lug? I can do that but what a PIA for 20 ends. What other options?
On another electrical question I have a new ammeter and shunt. It says to put the shunt on the negative side. I have found a number of wiring diagrams with it on the positive side. Is there any reason I can't put it on the positive side?
Thanks,
Dick
Thanks,
Dick
