Towed problem solved
These people have solved the question of how to get your car to your destination
This could open up a whole new discussion.
How do I get my crane/forklift to my destination to unload it?
Will my destination have a really tall ramp?
What is the best procedure for packing the stuff under the car?
Can I carry really long ramps so that I can load my car myself?
Is there a map that shows where the 18 foot underpasses are?
If I also carry my boat, can I leave it hooked to the car?
What are the pros and cons of tying down the car?
If I tie it down, what are the best tie down points?
Where do I get tires for my bus with a load limit of 50,000 lbs each?
The possibilities are endless.
Please post your comments/questions here.
Dick
Re: Towed problem solved
Stuart says, "Ha! I'll see your 2 and raise you 8"----- Jack
Stuart, is that what's known as a "Tasmanian Clustertruck?"
The above photo is from a site called www.cargolaw.com It's worth checking out.
And for your entertainment, I have added a few more from that site:
And you thought you knew what a stealth fighter looked like?
This is what properly integrated inter-modal transport looks like
Ever wonder what traveling steerage class means?
And finally, for those who doubted the thoroughness of customs agencies
Users browsing this forum: No registered users and 64 guests
