Fun with the Phantom
Re: Fun with the Phantom
For this particular toilet, a large kitchen trash bag fits over the top of it. You turn it upside down to empty. At this point, you can put the emptied product in an outside composting bin, or it can be sealed in the bag and put in a dumpster. If you're putting it in a composting pile, it would be good to use a composting kitchen bag.
Darryl
Smyrna GA
2000 Gillig Phantom
Smyrna GA
2000 Gillig Phantom
I finally finished the fresh water, shower, and composting toilet installation this winter. Here's a quick pictorial.
The composting pooper!
Drop Shower
This was orginally the location for the rear door. Just made a drop shower out of it.
The Fresh Water Tank
Because this is a transit, i installed the 100 gallon fresh water tank inside the bus, under the beds. Concerned about leaks, I built the enclosure and fiberglassed it. If anything leaks, it flows out the floor drain I installed. Space around the tanks was filled with foam. The tank fits tight and shouldn't be moving around any now. Pump on top is a Shurflo 24V.
Drop Shower
Darryl
Smyrna GA
2000 Gillig Phantom
Smyrna GA
2000 Gillig Phantom
Very nicely done. My drop shower required a separate holding tank (7 gal) and a lift pump to the grey tank. How does yours drain? Jack
Hmmm, functional, but not ideal. I wished I had made the bottom of the stainless pan with a pitch so water would not pool in the corners if you're not level. Too late for that now. This is the first one I've ever had made. Lesson learned. The drain out the bottom is still above my frame rails. I haven't hooked up the tank yet. That's coming next. But, it should drain good.
Darryl
Smyrna GA
2000 Gillig Phantom
Smyrna GA
2000 Gillig Phantom
I went with a natures head as well
Oh great! So tell me how you like it . . . . .
Darryl
Smyrna GA
2000 Gillig Phantom
Smyrna GA
2000 Gillig Phantom
I did pitch mine, I wish I had put two (or four) drains in it seems I'm never quite level enough.I wished I had made the bottom of the stainless pan with a pitch so water would not pool in the corners if you're not level.
Me too. But, even though it's not perfect I'd still rather have it than have to use the campground shower!
Darryl
Smyrna GA
2000 Gillig Phantom
Smyrna GA
2000 Gillig Phantom
Looks marvelous, Darryl. I look forward to seeing it in person this Saturday.
Users browsing this forum: No registered users and 77 guests
