Where did the forum go ???
Has the forum moved to another area ??? not under the table of contents any longer ???
Everything seems to work fine with me, just a little slower then usual, but that may just be my internet connection. I wonder if it would work faster or better for you if you 'signed up' and then signed in as a member instead of a guest? Maby your internet connections are restricting you as to what you can see and where you can go on a website?
I am technologically challenged, so I am not sure what may be the problem, but I am good at giving advice
Users browsing this forum: No registered users and 32 guests
