Looks like you are starting to make serious progress Rudy! I bet you are feeling a lot more confident about it all now.
The BIG air filter unit. I became frustrated working around it, so I removed it.
A QUESTION. What is that unit to the left of the air filter? I think it is a reservoir for power steering. There are more pics of that.
I have these nice wrenches. I used one to remove the air filter unit.
Here, the air filter unit has been removed.
It looks dirty in that hole. I cleaned it before I reinstalled the air filter unit.
A few pics of the motor. I traced the fuel lines. I will point them out later.
The rubber on the inside of the dog house is falling apart. I removed the loose stuff when I finished the fuel pump project. What is left on that surface is the fiberglass.
More to come.
I would like to take this time to thank all the "bus family's" responses to the fuel pump project.
Special thanks got to Chuckles and Dennis for daily phone calls and support.
Extra Special Thanks go to Chuckles who through a series of phone calls around the US found a fuel pump in Detroit. It was only $25 dollars. The pump, although 38 years old, was new in the box.
The box is cool. It is a CAT original part. I have a pic of the box.
I gotta put all my tools away now.
Now I will point out the flow chart of the fuel lines. I am using a screwdriver as a pointer. Look at where the tip of the screwdriver is touching.
The first pic shows the lines that come from the fuel tank and returning to the fuel tank.
In this pic you will see the screwdriver pointing to the fuel return line back to the fuel tank. Follow it up a little and you will see where it connects to a short rubber hose. That is where the passenger side cylinder sends fuel back to the tank.
Notice to the left of the screwdriver handle, you see a tee fitting where the two fuel return lines that come from the heads (one from each side) and meet.
This photo shows the return line from the driver's side of the engine to the tank. Follow the line up and to the left. You will see where it connects to the cylinder head.
This pic shows that the screwdriver tip is pointing to the line that comes from the fuel pump (lifter pump) that I just replaced. It goes to the fuel filter and then goes to a 12 volt valve attached to the injector pump.
The 12 volt valve shuts fuel feed to the injector pump when you turn the ignition key off.
Here is that valve.
Here is that valve.
Users browsing this forum: Baidu [Spider], Google [Bot] and 239 guests
