MrSharkey.com
Re: MrSharkey.com
Postby Stealth Camper » Sun Nov 29, 2015 12:07 pm
Re: MrSharkey.com
Postby Dennis The Bus Dweller » Sun Nov 29, 2015 1:37 pm
I got some down time comin up so I'll try and find out an if so I'll see if he will send me a few pic's of the crown
Re: MrSharkey.com
Postby Stealth Camper » Fri Dec 04, 2015 7:30 am
Tell him we wouldn't complain if he wanted to drop by and say hi sometime, too!
Re: MrSharkey.com
Postby Dennis The Bus Dweller » Fri Dec 04, 2015 7:32 am
Roger that
Re: MrSharkey.com
Postby Stealth Camper » Sun May 12, 2019 5:24 am
Looks like Mr. Sharkey has a low key thing going on again. Nice place the part that I have seen so far....
http://www.eugeneweb.com/~sharkey/privacy-policy
Graynomad
Re: MrSharkey.com
Postby Graynomad » Wed May 15, 2019 2:15 pm
Re: MrSharkey.com
Postby Stealth Camper » Wed Jun 05, 2019 6:41 am
And Sharkey is gone again....
Graynomad
Re: MrSharkey.com
Postby Graynomad » Wed Jun 05, 2019 9:18 am
Re: MrSharkey.com
Postby Stealth Camper » Wed Jun 05, 2019 1:24 pm
Graynomad
Re: MrSharkey.com
Postby Graynomad » Fri Jun 07, 2019 1:00 am
Ha ha, maybe :)
Re: MrSharkey.com
Postby Stealth Camper » Mon Sep 16, 2019 2:23 pm
Just to see if I can post something....
Graynomad
Re: MrSharkey.com
Postby Graynomad » Mon Sep 16, 2019 2:54 pm
[quote="Stealth Camper"]Just to see if I can post something....[/quote]
Looks like you can, but there are a huge number of PHP errors showing at the top of the page. Also it's not parsing the quote tag and most of the above posts don't show any content.
Re: MrSharkey.com
Postby Stealth Camper » Tue Sep 17, 2019 1:31 pm
[quote="Graynomad"][quote="Stealth Camper"]Just to see if I can post something....[/quote]
Looks like you can, but there are a huge number of PHP errors showing at the top of the page. Also it's not parsing the quote tag and most of the above posts don't show any content.[/quote]
Whew! Intensely messed up. Having issues like this is enough to make me not want to do a web site with forum...wouldn't have a clue how to even get started at fixing this.
Re: MrSharkey.com
Postby stuartcnz » Tue Sep 17, 2019 8:05 pm
The errors are because the server is running a new version of PHP, which is incompatible with the forum software. They will persist until such time as a new version of the software is released, that is compatible with the server PHP version.
https://hubzilla.nomadicista.org/channel/stuart
sip:stuart@nomadicista.nz (TLS connections only)
Graynomad
Re: MrSharkey.com
Postby Graynomad » Tue Sep 17, 2019 8:24 pm
Correct.
It may be possible to either install a newer version of the BB code, or select a different version of PHP on your server.
Also it looks bad but it's possible that there are only a couple of errors to fix if you have access to the code.
[phpBB Debug] PHP Warning: in file [ROOT]/vendor/twig/twig/lib/Twig/Extension/Core.php on line 1266: count(): Parameter must be an array or an object that implements Countable
Return to “Housebuses & Housetrucks”
