BlUE BIRD OF HAPPINESS
I agree with the guys--live in one bus while you fix the other
Bash On Regardless!
WOW, REDNECKS dream come true, a DOUBLE WIDE BUS, you could always have a patio in between the buses, put a big refrigerator outside with a keg tap on the front, BUT what would the Amish neighbors think then MS EZRABLU, just leave enough room to drive them out for a trip.
James in da GRAYDAWG
I ONCE WAS A MIGHTY GREYHOUND
I THEN GOT OLD AND RETIRED
I BECAME THE GRAYDAWG
Ok...The last photos of actual work done were showing the floor being lined with plastic, framed and insulated. Then I asked about those long heater hoses and rear heater and Chuck advised I should remove or replaced them with copper so there's less risk of them cracking and leaking....so since I had already built in a long spot for them to lay under the floor, I had to remove the steel case that covered part of the hoses and wiring, cut the floor out to expose the hoses and remove the blower. I also removed some "stuff" right next to the drivers seat (left of the drivers seat) I don't really know what it was for but I thought it was for the rear heater but Chuck told me yesterday it might be parts for heating the drivers area. Soooo, well, that sucks if it was because it's gonna be cold driving. So, when I go out there tomorrow I also need to check to see if I still have defrosting capabilities
Photos to follow....
Very sorry it took so long for me to return...I have so many photos and none of them are sorted so I needed to take time to find some and put them in some kind of order it was done. Especially since I'm winging it and really don't know how to explain what I'm doing or why
So these first photos are the rear heater and hoses prior to being built into the foor last summer....as you can see the heater, hoses, wires and that "stuff" we removed (like a built in table with vents under it - right under the control switchboard) beside the drivers seat on the left.....
These next three photos show what it looked like after I framed and insulated the floor last summer. The heater hoses are on the right under the plastic right against the wall then there's a 2x4 to the left of the hoses. It's kind of hard to see it these photos AND I have since torn it all out and removed the hoses, but I'm including these photos as reference to my great construction skills
I screwed a 2x4 into the floor about 5 inches away from the wall which left a space for the hoses to sit in. Then I insulated the rest of the floor, then laid the OSB flooring over the top of it all. The last photo shows a close up of the angle cut where the hoses come back out of the floor right before the wheel well.
This photo shows the floor completed and covering the hoses. I painted the blower black and there is a 2x2 laying on the place where the hoses are UNDER the floor. (just to show how much work it was to get them back out a couple weeks ago
This next photo is pretty self explanatory...the hoses are disconnected from the rear heater and placed in a 5 gallon bucket to prevent antifreeze from leaking everywhere.
In this photo, that long silver steel cover has been cut out, the floor has been cut out and the hoses and wiring have been removed.
Here that table thing with the heater vents under it right next to the driver's seat has been cut out and removed. This is the part that makes me worry there is now no heat and possibly no defrost function now. There is one more heater like this just as you come in the door under that dash called a "Hurry Hot". I'll post of photo of that, too.
Users browsing this forum: Google [Bot] and 119 guests
