Downhill Grades With A Bus
My lack of driving experience with my bus ( perhaps two hours ) has prompted to ask some advice.
I don't quite know what is the proper approach to safely go down a long grade.
The bus has an eight cylinder CAT motor in the front. It has air brakes. It has an Allison 4 speed automatic transmission.
My primary question is: Should I put the transmission in third gear in anticipation of a long run downhill?
I am concerned about the available air to keep my brakes functioning.
At an idle, if I depress the brake pedal 12 to 15 times all the way down in a quick succession, I can get the gage to buzzer in at 30 lbs. I have no clue if that is normal.
Those two items would be handy to know about.
Please help me with some answers. Thanks
General rule of thumb in trucks is to use the same gear going down a hill, as you would use to climb it. If you don't have any exhaust or engine brakes, you may want to go a gear lower still.
Either way go down hills SLOWLY!
PS. you don't want your brakes getting to hot, wich is why you want to use a low gear, that way you don't spend so much time on the brakes. You want them to be cold when you need them.
downhill
What the others said. A diesel, without an engine retarder of some kind, doesn't really have any back pressure (no throttle plate) to slow you down. I wouldn't use low, depending on grade and length of hill, assuming you have a 4 speed, pick 2 or 3. Watch the tach, keep the rpm's down, when it rises get on the brakes hard ( don't lock them up) to bring speed down fast and get off the brakes. This helps brake cooling and gives the compressor time to build air again. Don't ride the brakes, it makes them hot. Hot brakes don't work. You should'nt see smoke, if you do they are too hot pull over and let them cool. Most trucks loose brakes from heat not lack of air.
Rudy if you're going to Chatanooga, Mt Eagle is one of the worst in the country in my opinion. I did find an 11% grade on some back road in PA last week.
You'll be fine, just use some common sense.
Dick
Dick
WOW! Thanks for all your input. You have given me strength.
Here's an idea:
Imagine if you had many 2 foot by 2 foot metal plates in a line mounted along each side of the bus that were hinged in the rear of each plate. If you connected each plate with a rod, you could deploy them open all at once.
It would create a tremendous wind resistance which would greatly slow down the bus much like a parachute slows down a dragster.
Orbit told me that was an awesome idea.
Here's an idea:
Stuart, what you said about using the same gear going downhill as the gear going uphill makes such beautiful scientific sense. You are a genius.stuartcnz wrote:General rule of thumb in trucks is to use the same gear going down a hill, as you would use to climb it. If you don't have any exhaust or engine brakes, you may want to go a gear lower still.
tamangel
- Roving Reporter
look into getting a Jake Brake installed on your motor..
http://en.wikipedia.org/wiki/Jake_brake
and a vid of the sound..
http://www.youtube.com/watch%3Fv%3DUT4sHf1gYLI
FAQ's by the Jacobs company:
http://www.jakebrake.com/support/faqs.php
Mike
Mike
Users browsing this forum: No registered users and 226 guests
