Safe way to switch LPG solenoid.
Ratau
Post by Ratau »
A safe way to switch the LPG solenoid is to put a pressure switch connected to the inlet manifold. If the boost is below the set pressure say ± 3 psi the LPG is off. :idea: You don’t need the LPG at idle or low RPM anyway.
_________________________
Danie
Users browsing this forum: Baidu [Spider] and 107 guests
