Way-Cool Rolling Home (Trailer) Website
Hi,'
Yeah, it's a cool site and trailer. I'm thinking I'm going that route or build a truck slide-in camper. I want a vehicle to drive around without having to move the "house" when I park for the night or longer. I don't want to tow a vehicle either. I haven't seen many of those homebuilt. I guess I'll wing it like I do everything else. I also don't want many fancy things in mine to break down. I'd like solar though. Just not a lot of electronic or mechanical gadgets to have to service, access, replace, fix. KISS is my message to myself. What I'd REALLY like to do is get an Isuzu NPR chassis and cab and build a big easily removable camper on the back. Anyone have thoughts on that? Think it's feasable?
Phil
Phil
Illegitimi non carborundum!
Yes I think it's possible. Great idea. However you and your welder will have to become close friends. The amount of frame it would take to support a removable "dwelling" on the back of a commercial truck rail would be substantial. I think the Kiss theroy is a good moto to follow. Good luck!
-Richard
-Richard
Richard and all,
Maybe I should think instead about a flatbed on the back of the truck and then start building the house from there. Or, also thinking of a car hauler. They tip down in the back and have a winch at the front of the bed. Wonder if I could put rollers or wheels on the camper and let it down onto the ground and retrieve it with the winch? Would have to build light. I'm thinking SIPS.
What's you 'uns erpinion on that route?
Thanks,
Phil
Thanks,
Phil
You could go for a giant truck style camper that is raised with jacks or in this case hydraulic rams on each corner. Then just drive away and lower it down. The "camper" would need a strong battery bank to run the hydraulics, but it could be able to handle a strong unit. The next task is to find a comercial vehicle that already has or could accomidate a flat bed modification. It's somthing to consider...
Good luck with this unique idea.
-Richard
Users browsing this forum: No registered users and 40 guests
