And a few photos of my unfinished door...
This is the door after I removed all the door opening hardware and before I put the steel brackets on to hold it stiff:
This is after the steel brackets are on. I put them on the top, middle and bottom. I just used medium size brackets because I'll be putting wood framing and covering, too:
Kinda dark to see but a closer view of the steel brackets I put on with self tapping steel screws. Now the door opens like a regular house door instead of folding:
Not sure what to do with these wires that were attached to the door mechanism. I think they went to the flashing lights on top of the bus and to the light on the steps. Probably just cap them and stuff them into the dash.
And these are the steps which I need to somehow change so there are 3 not so tall steps instead of only 2 huge ones:
