Anyone got some good resources on designs and solutions for a crawl-through between a cab and house?
Also, is there much knowledge about housetruck construction and earthquakes (being in that part of the world right now)?
tia,
kouka
This is, or at least was, a method used for connecting camper units in the bed of pickup trucks to the open rear window of the truck cab, although the shape was more rectangular and it was made of a much thinner material, vinyl if I recall correctly. It really wouldn't have to hold a lot of pressure, just enough to press on both surfaces to prevent wind and water leaks. This also would have the advantage of providing a minimal amount of "insulation" between the exterior and the crawl-through, making it less of a heat loss.dburt wrote:you could use a large inner tube from an agricultrual type tractor tire
Users browsing this forum: No registered users and 31 guests
