Free Tv?
Free Tv?
Hey, have any of you ever heard of or have one of these boxes? http://www.roku.com/roku-products
TMAX
- Officer Hormel
Hi Dennis, I came across one of these things a little over a year ago. I wasn't that interested due to limited programming available at the time and didn't know that it had wireless capability (the operator had it plugged into his DSL service).
Just got off chat with Roku support and it looks like unit has built in antenna only (kinda like a laptop) which means limited range.
I'm sort of in the same position as you as I use free city provided wi-fi and need an external high gain antenna for access.
I will be researching this thing further to see what will be needed to make it work (if possible) for folks like us. I'll keep you posted.
Tom
Tom
TMAX
- Officer Hormel
My room (office) is only 9X12. I used to have a 46" Sony Bravia HDTV until our living room set went belly up and the wife took it. I would have had a larger set, only that the 46" set was the largest that would fit in my entertainment cabinet. I'm now using my mom's old (1987) 19" Zenith table top set with a converter box. My cousin has a 54" set in his living room and he watches it from about 12 to 14 feet away with no problem. He has had this set up for over a year now and is very happy with it.
TMAX
- Officer Hormel
Hello Dennis, have been doing some checking on the Roku and it looks like the built in wireless or ethernet connection (LAN, cable or DSL router) or nothing. Their top of the line model does have a USB port, but it is input only (memory stick, digital camera input, that sort of thing). It won't work connected to your cantenna. I will check further as to the availability of a LAN to USB adapter or LAN to wireless device. More later..
Users browsing this forum: No registered users and 181 guests
