1960 Crown TV Truck
Miss Priss
Post by Miss Priss »
Yes, please post more pictures!
Miss Priss wrote:Yes, please post more pictures!
Here is the photo from the WBRZ link I posted before, I can't get the link to work anymore.
This is my bus when it was new.
Miss Priss
That's really cool! Thnx :)
Post by ezrablu »
Chuck...is that your bus or just a bus like your bus? If it's your bus how really lucky you are to have that awesome photo of it!
Yes, it is the very same bus.
My bus is the only Crown TV truck that was 35' and only 2 axles. All the other TV Crowns were 40' with 3 axles.
Headache
Post by Headache »
Chuck, Sharkey and/or any other Crown familiar people...
When doing body panel work do you HAVE to have that tool set and fasteners or can you replace them with something else? Or did they stop using them by a certain year?
I'm asking because the people I've been attempting to deal with regarding a Gillig are excruciatingly slow regarding return contact. I'm about to give up and take a peak at a Crown schoolie.
Any welder/fabricators in WA state? :wink:
Headache wrote:Chuck, Sharkey and/or any other Crown familiar people...
I think you referring to the tools to remove any Gulmite fasteners. Yes if the bus you buy has gulmite fasteners, then you will need the driver to remove them. After they are removed, then you can replace them with a standard fastener.
Headache
Post by Headache »
Thanks Chuck, and I'm assuming that drilling/cutting them out in some way is not an option?
The only thing keeping me from looking at the Crown more seriously is that tool set....
Some ideas about removing Gulmite screws.
http://www.film-tech.com/ubb/f8/t004701.html
The only way to effectively work with Gulmite screws is to have a set of drivers.
It is possible to twist some of them out with pliers, but that will get old very fast on a coach that has thousands of them, and scaring up the metal behind the screw heads is almost unavoidable. Drilling them out is equally untenable, as they are made from some very hard steel. Cutting a slot in them is simply a waste of time, unless you used a CNC machine to make a perfect square-bottomed, parallel-sided slot, no screwdrive will grip them.
In desparation on some of the damaged screws in my bus, I tried to slice the heads off with a pneumatic chisel. No go, they ended up tearing the base metal into an oblong hole until they no longer had a purchase. it was very destructive to the bus construction. Luckily, only a few needed this treatment.
Once you get them out (using the proper tool) put them back in, these are some of the higest quality fasteners I've ever seen!
Since we're on the subject: http://www.mrsharkey.com/forum/vwtp.php?t=1270
Post by ezrablu »
I never heard of Gulmite screws....I just had to google it to see what they look like and yes, I've seen them before but never knew anything about them. I've learned a lot about them from this thread.
Thanks again :thumbup:
I have a set of drivers, but if I didn't I would see if a stud welder would work on the end of the screw.
However I got them out, I would never put them back in.
There are too many high quality screws on the market to use screws with an obsolete head.
http://www.youtube.com/watch?v=SjLb-Sj6 ... re=related
Headache
Post by Headache »
Okay, the other bus I'm interested in is a 73 Crown Super schoolie and it has some rust on the hinges, the rear emergency door and there is a panel he claims has rust on it(above the right fender about 2 feet back from the door). I've asked for clearer pictures of any rust that wasn't "normal" to a Crown(like the emergency door, anyone have a fiberglass replacement collecting dust somewhere?) or where there are actual holes in the metal(aluminum?).
Did they use those fasteners on the 73's? If they did I'd be screwed if I bought any Crown using those fasteners.
Since Crown coaches have aluminum bodies, rust isn't really much of an issue. the only steel panels on the exterior are the corrugated belting on the sides, and it's very thick, high grade steel, which is unlikly to have rusted though no matter how badly it's been exposed.
Emergency doors havesteel framing, but the corrugated panels on them are aluminum, so no rust problems there. Things like hinges are made of ~very~ thick steel, and are not prone to rust-through.
Maybe others have a first hand experience with later model Crown coaches, but my guess is that a '73 is going to have Gulmite fasteners. Someone is going to have to either find a source for drivers, or else begin manufacturing them, otherwise there'll be even more Crowns being scrapped out.
Headache
Post by Headache »
The only Gulmite drivers I can find are single size ones from locker parts supply companies. Since there were at least 4 sizes of Gulmite fasteners and that bus has them all over it, I'll not be shopping for a Crown anytime soon. =(
Users browsing this forum: No registered users and 73 guests
